I’m trying to import this SVG I made for a clock face in Inkscape, but when I do the ticks and numbers are not properly aligned.
Easel project: http://easel.inventables.com/projects/d0TTJ2Edm7w_FN5UScwpgQ#
Thanks for any help!
SVG file
Are you saying the shark is causing the numbers and ticks to be misaligned or should I import them from different files.
SVG clocks
make sure that the vectors are locked together as one vector. I think that should solve proplem
Don’t know if it’s your issue, but some SVGs that I grab off the web are a glob of individual pieces. You might be able to move/align the numbers then ‘combine’ them with the rest as a single unit.
I solved the problem, the ticks were clones, I unlinked them and it worked.
