Problems with easel HELP
I iam trying to use projects from easel and trying to do simple signs in easel but I either get the letters offset from each other or the program carves correctly then sets over about 4 inchs and starts carving it again over what it already did any ideas?
Can you post the file you’re using and some pictures of the results?
Chances are that you have a problem with the belt tension, allowing the stepper motors to skip steps, thus continuing in the wrong place.
If you haven’t turned up your y-axis voltage on the grbl shield, you’ll probably want to do that.
