Is there a way to calibrate the steps correctly? I do have home switches.
I did find these setting now. Thanks. I have been messing with them all day to see what works.
this video will walk you through it
Should the video ever go down, the steps are
- Start at your home position, and mark it
- Instruct the machine to move a specific distance on the axis you are calibrating and mark that position
- Divide the distance you told it to move, by the measured distance between your marks to get your Correction Factor
- Multiply the Correction Factor by the current setting of steps / distance for that axis, and save the new number
- Repeat test to confirm accuracy
- Repeat test for each axis
the larger the distance you use to test with, the higher the precision, as long you don’t hit the end of the machine travel
