Procedure to Set Belt Tension
If you use a controller with proper feedback the stepper motor will not keep trying to turn when the router / spindle runs into a point it cannot go beyond.
The standard controller that comes with the Xcarve does not have that feature.
At some point I plan on getting a controller that I can set up that will not have this problem. That way when I try to home or something gets stuck the unit doesn’t keep trying to move and will go into a fail / warning mode letting you clear or reset it.
Something like this:
https://www.inventables.com/technologies/3-axis-dsp-based-digital-stepper-driver
I tryed to centere the belt in the pukky and smoth idler and tited the belt and move in y axes 2 times or 3 and noticed that the belt was not aligment
Hi all
I have problem with circles
see https://discuss.inventables.com/t/aspire-why-my-circle-not-round-perfect/96222/5
I checked the belt tension it was x=1.8 , Y1=1.4 , y2=1.8
Do you think my problem from belt tension?
Hello. If I’m having issues where on the left side of my waste bored it cuts deeper vs my right side. Is that a tension belt issue? My Gantry is straight, so is my MakerSlide.
Na, depending on where your located humidity might be a factor in this. possibly your waste board needs planning for a well-tuned machine.
CNC BED LEVEL | Inventables
In addition to Surfacing the wasteboard as Ken is suggesting I also suggest to Surface the workpiece whenever possible and when it cannot be surfaced on the cnc for one reason or another I suggest trying this shimming technique to get the top of the workpiece to be parallel to the gantry plane of movement:
However I see that you’re new to the group and that makes me think that maybe you have a newer X-Carve and this video covers the most common first post from new X-Carve users and is worth checking out:
Noob alert. Here’s a crappy jig I built to tension the belts. The scale is from amazon. (Or search for " Didiseaon Spring Scale Spring Hook Scale") It’s pretty self explanatory. The belt lift distance is approximately one inch.
