I have had a number of folks ask me about milling my aluminum parts on the X Carve with the new VFD spindle. I am going to let the pictures do most of the talking and welcome any questions.
500x500 X-Carve with: Upgraded NEMA 23 185oz 3a steppers, Planet CNC MK3 controller, 4X Leadshine DM442 DSP drivers, 1.5KW 220V VFD & .8KW water cooled spindle and forced air chip clearance system. End mills used: 2.5mm 1/8" shaft carbide drill, 1/8" 3 flute Destiny Viper “Stealth” coated end mill.
Since I use a more advanced controller from Planet CNC which is no longer GRBL, I can not use UGS, Easel or Chilippr any longer. The controller runs on standard RS274/NGC G-code instead of GRBL. So it is fully compatible with Gcode from MESHCAM, V Carve Pro, HSMxpress and HSMworks along with SolidCam and many others that GRBL at times has issues with. It understands and uses advanced Gcodes like G40,G43, G49, G54 and such. Planet CNC has their own advanced Gcode sender/GUI. It is closer to MACH 3 than it is to Chilipeppr and such. It is not cloud based so no more worries about internet issues or needing to download a new version of a server to fix a bug or work with a new update. It has many great advanced features which work great on both a small mill like the X Carve such as 3d digital probing/mapping and auto leveling, full support for GERBER file milling (PCB), along with native support for DXF files and even some great features for larger mills like automatic tool change and support for up to 9 axis mills. I switched all three of my mills to it after experiencing a growing number of issues with a TinyG and Chilipeppr. Since switching I have had zero controller caused issues. Now just down to good old fashioned human error on my part.
Enough talk. Picture time!
Forced air chip clearance system test mount.
<img src="//discuss-assets.s3.amazonaws.com/original/2X/4/475f18f8ed79ecd5c297b1cef81c9881394bb571.jpg" width=“690” height=“388”
Closed loop .8KW water cooling system mounted atop mill enclosure.
167mm x 200mm 1/4" Alca 5 5083 aluminum tool plate with 173 2.5mm drilled holes. These are later tapped to M3 with a tap head on a drill press.
5 reference holes are used to hold the plate down and center hole is origin point (X0Y0). My days of milling with the TinyG and Chilipeppr taught me to drill these holes on the outside chance I needed to rezero after a crash. Old habits die hard though as the new MK3 controller is rock solid and these are more habit than needed now.Mill is cutting down about 4.75mm in this cycle to produce a raised flute on the pieces. The forced air system is keeping the cut and area around it clear of chips.
A few hours later and the 174 raised flutes have been milled. The amount of chips is impressive. The right side of the plate shows the area of the final cut and how free of chips it is compared to the rest of the stock.Nice clean cuts and good holes. So far so good.
Again the area of the last cut is clearly shown by the clearance of chips by the forced air system. Looking good and ready to be unscrewed.
Ready to hit the tumbler and be prepped for anodizing then off to their life as part of a carbon fiber end cap for a 3D printer hot end mount.
Larger format: 168.75MM x 320.675mm 1/4" Alca 5 5083 tool plate. End mills used: 2.5mm 1/8" shaft carbide drill, 1/8" 3 flute Destiny Viper “Stealth” coated end mill, 45 degree 4 flute Chamfer end mill.
<img src="//discuss-assets.s3.amazonaws.com/original/2X/d/def32cf259a97682d7b08a03285d00ac1eab49d3.jpg" width=“690”
2.5mm holes drilled and #2 sheet metal screws inserted. Lots done here.First more 2.5mm holes drilled with pecking cycle. Then end mill changed to 1/8" Viper. Screw recesses milled, End mill change to Chamfer end mill. Screw recess Chamfered. Viper end mill changed back in then screw hole bored out and finally screws added to hold down mounts once they are cut free. A shallow 2.5mm recess has been milled in on the flat sides of the center recesses. Then a 13mm circle has been milled down 3mm.
Chip clearance system doing a great job of keep the cut clean. Rest of the mill is mess which is fine as it is enclosed for this very reason.
All done and ready for cleaning and anodizing before heading off to become a hot end mount for a 3D printer.
Prepped for anodize
Details of the stepped center cut
Final products all come together.
So if anyone really wants to know the secret behind great aluminum milling it is really pretty simple…
More than willing to answer any questions if anyone has them. I am not an expert by any means but I do seem to get very good results so far. The VFD spindle is really good and the right end mills really make a huge difference.
