Twice in a row now I have set up my piece in Easel to cut outside the tool path. After downloading to
my machine and starting the program it starts cutting ON the tool path. I look back at Easel and it still shows “cutting outside the tool path” and both illustrations show that. Any suggestions?? This is the
first time this has happened. Should add; when I downloaded the file into Easel I set the parameter
to cut outside.
What bit diameter do you use/set up in Easel?
Thanks for responding.
I tried both a 1/8" and 1/4". It dawned on me that while I had laid out my design vertically,
Candle was displaying and cutting it horizontally as well as cutting on path. Cure was to restart my PC
which I use for Easel layout, and restart the laptop which I use at the CNC and reprogram
everything from scratch. Don’t know why it fixed it, or why it went off, but I’m not complaining.
Good you got it sorted
Whenever something funky goes on, for trouble shooting purposes its best to stay 100% within Easel to rule out any mismatch between design program (Candle) and sending software (Easel). Something may be lost in translation
