Can someone explain why this purple line / purple box is showing up on my design when I change the cutting dimensions? I can’t get rid of it or change it. I have never had this issue before.
I don’t know if this helps but when i turn tiling on I see a purple box around the section that it is going to cut.
I am having the same issue, my piece is 18 in by 18 inches, using the longmill 30/30. How do you remove this? I checked the material options and I don’t see anything that says disable tiling? I am a newbie so struggling with it. at a standstill.
