So I’ve been tasked with making several signs for our company on 1/8" thick acrylic(red sign/white lettering on the inventables store). But I am uncertain what sort of feed rate I should use as this will be my first time having to work with acrylic and the person who did this before no longer works here. Any help would be most appreciated!
From what I’ve been able to gather online, I should use the following settings:
Depth of Pass= 0.01"
RPM= lowest setting, our xcarve has the dewalt 611
Thank you, I forgot to mention that they want a 1/32" bit used so I would think that’d require a slower feed rate or is that 80-90 in/m range still good?
