do I need to use a probe when doing a tool change with easel?
Yes. When changing the bit the second bit will probably not be the same length as the first bit.
Yep! Every-time you change the bit the distance between the end of the bit and the work surface will change. You will need to zero the z-axis each time to keep it consistent between cuts.
