Question about repeatability of missed steps
Recently my x belt broke. I got a new one and installed it a few days ago. My first carve then was a test run of an about 8 minute carve. That went fine so I did a second carve of the same pattern. That carve did fine also so I did a 3rd carve, again, same pattern. About 90% through that 3rd carve it missed steps. (I was watching it when it happened and it was a rather odd jump-around of the x carriage for a moment there…enough for me to realize something bad happened.)
When the that carve completed, and the router returned to it start position, the bit was about 3/4" to the left from where it should be. I am not sure if the y direction was off as I didn’t think to look at the time - I just started moving things around to remove the material.
Upon inspection I noticed that 2 of the stationary v-wheels on top of the x carriage could spin freely (they were cross corner from each other). I gave the corresponding adjustable v-wheels a very slight adjustment and now the stationary ones won’t spin easily. I reloaded some scrap MDF, loaded the same carve pattern, and run it 3 times back-to-back with no missed steps.
Now, to my question which may have no comforting answer but I’ll try…I did 2 carves and those went well, on the 3rd one I missed steps. What is the repeatability of those missed steps on subsequent carves? Had I not made any adjustments to the wheels what are the chances of a 4th, 5th, 6th, etc carves also missing steps? Ignoring the fact that new problems can happen at any time, how confident can I feel that my adjustments fixed the problem?
Of course I could run 10, 20, or even 100 tests and the higher the number with no failure the better I would feel. But, given my sample of 3 successes…??? For those of you with with many carves, and preferably, many instances of missed steps, what are your thoughts?
And, I’ll put this out there…were the missed steps caused by the loose v-wheels or are the loose v-wheels a result of the x-carriage’s quick jump and shake when it missed steps?
Many thanks,
Randy
How loose were your wheels,you shouldn’t be losing that many steps (3/4") from loose wheels. What are you cutting, feeds and speeds.
Loose wheels will allow the belts to flex. Depending on how loose the wheels are your belt can slip across the pulley teeth. Missed steps.
Approx 5" x 6" in size. 60 deg .25" V-bit with a cut depth of .0312" (total of 1 pass) running at 60ipm into cedar.
Almost like they were not touching the rail (the non-adjustable ones on the top). With my finger on it I could roll it back and forth and feel no resistance. What I found strange, however, it was difficult to get the corresponding adjustable wheels to turn. I was able to pinch them with 2 fingers and get them to turn (which, my understanding, is what you want to set them to) but not without effort. It wasn’t any easier or harder to turn those 2 adjustable wheels than it was the other 2. Before I installed the new belt, the carriage rolled quite freely on the rail.
Thanks
What belt did you replace,if it was the y axis did you check that both were the same tension? Speeds and feeds are fine.
The x one
That makes total sense. I will do that. Thanks!
I appreciate the input on the wheels but, to my original question about the repeatability of missed steps…if it happens during a carve what are the chances of it happening again on subsequent carves? 50/50? very good chance? just never know?
The reason I ask is because after I make a correction and the following carves are good, how confident can I be that I resolved the issue? I realize there are many variables to the equation and there is no solid answer, just looking for gut feels.
Thanks
