I have noticed when using tabs, I am unable to locate those tab as they are placed automatically. Sometimes a Tab ends up on a corner. Before, the bit would raise above the work surface, as mentioned, but then it would “cut the corner” i.e. it would move 45 degrees to the next location before lowering back down instead of following the path at a 90 degree around the corner.
My question is this, does the improved tool path account for this and it will raise a bit, then follow the corner or will it try to move 45 degrees to the next point?
Thanks
on a side note, I would like to be able to select the tab location - or am I missing something? (I would check to make sure I didn’t miss it, but for some reason Easel won’t connect. server down maybe)
