When I click the raise bit button in Easel, it raises the router until it activates the homing switch and its way above the wood. This began today when I went to carve. Please help!
même problème.
il monte au maximum puis il se met à sculpter dans le vide
What increment of z do you have set? I mean if you ask it to raise 20cm for each button increment it will slam into the top. God have I done that a gajillion times. I leave it on 1-inch thinking I had it on 0.1 inch and bam…
