When using barn wood. Iwill set the bet even with the corner of the wood. Then when it statrts the milling step it will drag the bit over the surface of the raised part of the wood. It would be nice it you could select the amount that it raise when going to the next area. Or as my Mom would say pick those feet up.
it is set at 0.15. is that what I need to aadjust. Thanks
it was the height of the step. I didn’t know it was set able to various height.
