Hi Folks,
What should the range of the new z axis be?
How low or high should one mount the Z Axis to the
the X Axis?
Please advise,
Thank You
Martin
Hi Martin, most users will be cutting through material at some point, so unless you have Extra long Bits, I would take the shortest bit you have and make the height such that the shorted bit can reach the wasteboard.
But it’s kinda up to the user, some users will need a higher mounting position to accommodate thicker stock, where as other uses who are machining thinner stock will need a much lower mounting position.
WOW Thank you!!
God Bless,
Martin
