So I designed a job and some how my red simulation line goes way off to the right of the screen and comes back a couple times. I cant get to it to find out what is wrong. Any ideas?
I would say there is something it is going over to carve. You need to check and see if maybe you moved something and forgot to delete. Can you share the file here?
Ok guys I fixed it with my wifes help.
Good for her. What was it?
Some how when I set up the job, I copied some images and they got way over there on the right. She suggested to shrink the design screen and I saw it there. I was able to delete it and go on. All is good.
You can also do a ‘select all’ and it will show you a bounding box encompassing every object in your design.
