I am pretty sure I asked about this later year , but just in case.
A big benefit would be able to select multi layers and reduce the cut depth by a percentage , instead of having to try and select each layer and reducing them one by one.
I just got an app approved that should solve this issue. It’s called “Depth Changer” and it allows you to change the depth of multiple shapes at the same time while maintaining their relative depths.
It does it by a numeric depth instead of a percentage. Would being able to scale the depths be useful?
Hi Ethan,
Sorry for the delay busy time of year for us. I gave this a shot but it didn’t appear to do anything.
Could you give a brief tutorial on how to use it?
Then I can answer your question
Many thanks for your work on this!
Hi Debbie,
Sorry for my delay!
The app works by:
Note, the app will show your entire design, however the depth will only change on the shapes you have selected.
I hope this helps! let me know if you have anything changed.
-Ethan
