FoxAlien 3018 SV using Easel Pro: Can I start Easel from the begin? Having several issues I can’t correct. (1) when I hit send on Candle spindle goes to top right and stops (2) Spindle will not start. If I can reload Easel maybe my issues can get corrected. Thanks.
In Easel you’d need to go to Machine>Edit Machine and set the Spindle Control to “Hardware” and the type to “other” and set the RPM accordingly.
But also, What are your grbl settings?
AND as to the moving to the top right, have you verified the toolpath isn’t telling it to go there?
Possibly you’re not setting the X,Y Zeros properly in candle?
Thank$ < $0=10
$1=0
$2=2
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=150.000
$25=625.000
$26=0
$27=1.000
$30=10000
$31=0
$32=0
$100=700.000
$101=700.000
$102=700.000
$110=1000.000
$111=1000.000
$112=600.000
$120=600.000
$121=600.000
$122=600.000
$130=200.000
$131=175.000
$132=200.000
ok you for your quick response! These are my grbl settings. Don’t know what each does.
