I am trying to make a Bowtie inlay out of 2 triangles. I overlap the 2 triangles point on to get the shape. this lets me cut out the hole for the inlay but i need to remove the interior line to keep tje inlay whole when i cut it out
Select both triangles and combine. Ctrl + J or Edit Combine.
Remember to select both triangles
Russell
Thanks… worked like a charm
is there a listing of all these commands
You’re welcome and welcome to the forum,
They don’t have a lot of commands, but if you select Edit it will have the commands and what they do.
You need to have something selected to see most of the commands on the Edit tab.
You need to have 2 items selected to see the combine function
Good Luck
Russell
Edit: I forgot about the E key. If you have something selected you can hit the E key and it will show the nodes on the selected object. A window will open up and you can edit the nodes.
