Every time I repeat a project,or make multiple cuts of the same project at the same time.most of them cut out different sizes.either longer or taller, not by much,but different .
This can often be the result of a machine that needs a little maintenance.
Check v wheel tension
Check belt tension
If you need to see the steps, both of these are covered in the last portion of the manual.
