@ChristopherMay sorry you struggled with this one. We have a new design in the works that we will be rolling out.
@JohnHayes can you please add a note in the instructions to address what @christopherMay is talking about?
Also quick note that anyone can update the instructions now. You make a request and @johnhayes will review it and approve of give you feedback.
We are hosting them on github which is used as a version control system.
Thanks Zach for the quickness as usual. I still am struggling with it sweating in the shop. None of the belts will stay. If there was another hole in the bracket the belt could be double bacadn.ith a push pin and double backed through the loops using the pin as an anchor. It rest on the rail and seems to work.
Sorry the text got scrambled when I tried uploading pic. Double backed⌠âi improvised with a push pinâŚâ
What is the new design?
I think they are still testing options.
The bracket doesnât need more holes. If youâll change the routing as I showed in my post above, the belt will get locked in securely.
BillArnold you are using a clear piece of hardware that is not what I have. 2nd I tried it already.
The video at the end of the build for tuning the machine has a clearer explanation of how to keep friction with your finger to tighten belts⌠I will try it again but I have just moved on. Im soooo close to finishing!
You have a bracket with two slots in it. My bracket is the same. The reason my bracket looks different is that I needed to make a slightly wider bracket to hold the 9mm belts I chose to replace my 6mm belts. I used my SO2 to cut a bracket modeled after the stock bracket. I had some Lumicite (acrylic embedded with fiberglass) in my stock, so I cut six brackets to replace all of my stock brackets.
I had noticed with my 6mm belts that they would flop around a bit, even when snugged up real good. Exploring other ways to route the belt, what I show locked the belt securely. With the routing shown in the instructions, there can be a variable amount of pressure keeping the ribs of the belt interlocked. With my routing, there is no slipping because the ribs are locked together well.
I like your solution for what you have done. I am not sure why you would say that 3 slots in the bracket is not helpful. If the bracket had a 3rd slot I bet 98% of these belt questions would disappear.
I canât help, if you donât mind I have to pass this to you Zach. Here is what I did to my belts and still staying.
Winner! The second insert nut gives additional bearing surface for the belt to rest against in the maker slide and the upturned portion of the nut tends to bite in a little on the belt improvoing the grip.
I am almost done with the build. I stopped early last night after I finished the âwork areaâ section. I tried tightening the belts and they slipped so it was late enough to take a break. Today is a new day! I will get it somehow. I like the solution suggestions above thanks alandavis. I was also thinking if I took that bracket and gave it a few degrees downward bend it would press harder on the belts when I screw it down.
It will bent back again. Also problem here is there is nothing under the belt to hold together. Thatâs why I insert that nut. If you donât want to disassemble again, you can insert thick enough metal piece to support that down push. Target is pushing belts teeth tightly to each other. I hope helps.
Itâs been 14 days. still holding, no belt adjustment made since then. Just for the reporting.
Itâs been 36 days. Still holding.
Same here, with zip ties, for 57 days.
You didnât have X-carve 119 days ago.
