The project I’m working on does not appear in its entirety in the Working Window. In the preview window the grid is not showing up under the drawing. I can only see the bottom part - about 125mm in the Y-axis. Am I doing something wrong? Can someone please tell me how to expand the view?
Check your material size. Or rotate you part.
Thanks for the reply, David. I tried it but it made no difference. I still only see part of the drawing!
Thank you, Phil. That was the answer I needed!!! Is there ANYTHING you don’t know about this??
I don’t use easel but I noticed the size in the photo. I was close.
Thanks again, Phil & David. It’s so nice to have such good and willing support!
Much appreciated,
…Gord
Yes, it worked. I haven’t carved the project yet but I can see the whole thing and that is what I was having trouble with. Thanks for asking!!!
Bringing this one back from the dead. I’m having this same problem with my new computer. What was done to resolve it?
@CoyHaney. Using the mouse the wheel will reduce the preview to see everything. Left mouse youcanmove and rotate.
