I am having difficulty resurfacing a piece of wood before I carve. I have a 7.5 x 7.5 square I want to resurface flat, then flip. Using the 1.25 bit that came with the Pro to resurface the wasteboard.
I home the machine, I set xy zero to the piece and then hit carve. When it starts to resurface it offsets the surfacing area, leading off 2 edges, top and right, by 1/2 inch then doesn’t go all the way to the left and bottom edges, leaving the same 1/2 inch.
How do I get this to surface the entire piece?
Thanks in advance!
