Returning home after finishing the job problem
So i prepare for the job on easel set zero point ( home ) run the job but after it finishes it does not retung to the exact same point its just a 10mm aprox to the left. I dont think its lost steps since whatever job i run seems to be almost perfect in dimensions.
Any suggestions?
Have you calibrated your stepper motors?
Yes my steps are spot on. Thought this was by design since easel remember your last home position but wanted to make sure if its or there is an issue with my setup
