Right going to the left
Hello people .
I have a niggle who can help
when I told the xvarve that fence down when going up and motioned to the right going to the left.
what is the problem? thank you very much
when he begins to walk it goes against the rails
and fix the problem right and left but always starts When going Against lis rails as if measuring wrong .
what do I do ?
Running Machine Setup one more time might help.
already did
did you get this sorted?
Dan
already solved
what did you do having a similar issue ?
thanks Dan
I connect with inventable suport and connected with my pc and solved the problem. when happened to you? my when installing the universal gcode sender
