Hello everybody!!
Just made a protoype for a Roland cutter to attach to CNC machines…you can find info about it here.
DIY Garageprojects - Roland Cutter!
Below is the two first cuts done in normal A4 paper.
It costs next to nothing to make, and I am just starting to grasp the potential…gonna have a lot of fun with this one Hope you like it, if you have any questions let me know!!
Brgds
Christian
Looks awesome. Can I ask what the Xcarve Settings are? feed rate, depth… Thanks
Dead @TonyNo ? Can you please try again, I just tested it. Hm…
Here is the URL for the blog itself
Hi @psharley
I do not have an X-carve anymore but a custom cnc. I also do not use easel but Estlcam. However it should be no problems doing this with easel. Just create a tool with as small diameter as possible (I used 0.1mm). Then make a cut 0.1mm deep.
I used federate of 600mm/minute.
Brgds
Christian
