I want to put some script and an image on a piece that is 4’ x12". to carve I will have to install the material length ways along the “Y” axis. How do I rotate the image to run along the “Y” axis instead of the “X” axis
Select the image you want to rotate, then select the Shape tab, then go down to Rotate and type in your degrees.
Russell thanks for the info looks like it will do what I want
