Rough/Detail cut
New 2 stage (rough/detail) cut from yesterday. Measures 7x14 in Monkey Pod wood. Used the paper (wax paper) method for Zero Z. Worked out ok, just a ever so slight difference in cut heights. Just a scratch line. Went from .125 to .0312 bits. Next cut I will try the new ohm meter touch plate I made. Getting close to finding a way to set Z zero I like.
Smooth :smile:
Was this done in Easel?
Yes Jeff. All Easel.
Cut in Easel, designed in CorelDraw
Nice.
How much was actually cut with the roughing bit?
I would say maybe 60%. Just large areas. Took about 45min each cut.
