Hi,
How do I round corners of my project or make it oval, etc?
Thanks
Hi,
Thanks
If you have your sqaure or whatever drawn up highlight it and instaed of shape go to cut and you should see it there.
I think the only way you can round corners of a square is if you create the square in Easel. Draw the square and get it to the size you need then go to the shape window and you will see Corner Radius.
Thank You
