Hi,
I use my X-Carve primarily to cut panels for mounting items on the dashboard of boats. I typically cut marine Starboard, a HDPE product, and I’d like to use the router to roundover the edges. I have an Amana tool 56144 1/2" radius by 3/4" depth roundover bit, I’ve had some success cutting a hand modified tool path around the outside of the work piece, but it does seem to be varying success. I’m wondering if others do this regularly and have a better way of rounding over the workpiece.
I have a router table and can run the piece through the router table with a bottom bearing router bit in that, but the material has a nasty tendency to grab and bite going through the router table, so I end up wrecking a lot of finished pieces.
Thanks!
Ben
