I am playing around with my router while I wait for my controller and noticed that all of my bits have a 1/8" shank. The collet that came with my router is a 1/4". Should I have received a 1/8" collet as well with my X-carve or is that sold separately?
Agreed but broken bits are scarier and it should be stated. High speed rotating metal breaking and flying around…if thats not enough to spend a tad more for a true collet then I don’t know what is!
Better is relative. I believe the Inventables is a PreciseBits collet which has a lower static runout than the Elaire collet. Elaire doesn’t really state their TIR. So, from a static runout perspective, the Inventables collet is better but is the difference worth the added cost? For me, it wasn’t it but I’m also not going for super precise dimensions and cuts.
I have had both style of collets for the Dewalt 611 and from my experience I can say not only will the precise bit collet have a lower run out but it will be easier to remove form the router. I would occasionally have the elairecorp collet stick in the router and I would have to use a screwdriver and a dead blow hammer and tap it out, this would make me very uncomfortable as I felt like it was going to drive the router shaft out of the router. Since I have moved on to the precise bit collets they are easier to install and remove and I feel like they have better contact, also I have never had a bit “stuck” in the router where I had to forcefully drive it out.
you can buy a kit with both or buy just the nut or the collet, they also interlock. I just quit using it after about the third time I had to hammer it out.
I bought the elairecorp collets first because of price, but after using the precise bit collet at work I just went with them and never looked back.
