Does anyone have a idea how I can take the router insert plate that I have from Rockler and make a easel design for me to inlay it into a board as shown?
I am making a router table insert for my table saw and want it to go in to melamine.
Found this example on the web.
If you place it on a white background with a ruler next to it, you should be able to get a good enough image to trace. The camera angle will need to be exactly perpendicular to the plate. When you get it into Easel, you can lock the X & Y aspect ratio and resize it such that the ruler dimension is correct.
Other than that, have you tried looking for a schematic of the plate? Making the design in Easel would be trivial if you had the schematic.
