Is there a way to set the height when the cnc returns to start after finishing? It never lifts off the material high enough to clear anything and keeps buzzing clamps.
Go to machine >general settings
Here youll find 2 safety heiggr settings, the one on the left is for the majority if the carve, you can generally keep this low
The setting on the right called “origin safety height” is for the first and last moves to clear those clamps.
If the origin is set lower than the standard than the standsrd also applies to the first and last.
