Scale of imported SVG from OpenSCAD
I have a CAD model built in OpenSCAD and am able to export an SVG of the part to be carved just fine.
However, when I import the file into Easel the scale is way off. Since SVG is a “unit-less” format, I assume Easel just imports them as 72 pixels/inch or some other common scale used by graphics programs. In the case of an OpenSCAD export, however, the scale is (generally) 1 pixel = 1 mm, or 25.4pixels/inch.
I can obviously scale the OpenSCAD drawing before export, but it seems like a better workflow to allow the SVG to be imported directly. Is there, or could there be a way to allow users to control this directly?
Barring that, exactly what scale does Easel use when importing an SVG, to allow pre-processing on my end?
thanks
After you export from openscad you can simply modify the svg generated by adding information of units in the width and height atttributes.
svg width="20" height="20" viewBox="0 -20 20 20"
To:
svg width="20mm" height="20mm" viewBox="0 -20 20 20"
