I’ve imported a file (svg) and it worked perfectly but I want to scale it up 25% - how to do that?
select the SVG and then over on the “shape tab” of the popup there are the dimensions and a little “link” button to lock the aspect ratio, click that button then set the desired size for length OR width and it will re-size both together so as to not stretch it… Everything that you have selected will scale together…
Also this is the button to upload images (per your other thread)
