Scan full size drawing and transfer to easel
Can I scan a full size drawing and copy to easel?
You need an SVG file. So the answer is probably yes, but not directly.
Depending on the quality of the scan you should be able to import into Easel directly using the image vectoriser to give a SVG.
What is an image vectorizer? I am very green at this in fact I don’ have an x-carve yet because I can’t afford one right now
