I assume that you’re looking for advice on the fuzzies.
David and Rick are right that this is “normal” surface condition using an upspiral bit. If you look into using a downspiral bit you might have better luck on the surface finish, but the tradeoff is lower feed rate. I did a thread on this topic that might be of use to you. See here:
