Can someone please explain what the select by cut type means and actually does in easel please in the edit menu.I have hit the button and i see Outline,Fill or Drill but after that I am lost as to what this actually helps you achieve.Thanks
When you go through that menu sequence selecting one of the options, Easel will select all of the objects in that Workpiece that are designated as the same type specified by the button you chose. For example, if you have one outline and three “Fill” shapes (i.e. pockets) and you choose the “Fill” button, Easel will select all three “Fill” shapes in your design.
It’s just a quick way to select all objects of the same type.
{:0)
Brandon Parker
