Hey my friends, I have an issue cuz I’m new to this machine and every aspect that goes with it. I downloaded an svg file with multiple designs on it . I want to select just certain ones. Each different design has a box around it so I’m thinking this is possible. Can I get any help? Thanks in advance, Jim
k
Each shape is made up by nodes, these can all be edited or blocked out.
You could also try to use the Xploder-app in Easel to breack the single, all shape object into several smaller objects.
To edit click the object of choice and hit E, now edit/delete any node you choose.
To block out, simply add a new shape above the parts you dont want and set that to zero depth. It will hide whats underneath which will not be carved.
