Selective cutting
Hi
Can you select some elements cut, select new elements and then recut without having to re position the z axis. this would allow manual optimisation. holes are particular problem at the moment as they intersect with shapes but slow down the tool path a lot maybe holes should be grouped on there own? or a “cut each path separately” might be very useful in a lot of cases this would speed up 2d cutting an amazing amount.
Thanks
If I’m understanding what you want to do, you could select all the elements you don’t eant cut, set them to a cut depth of 0 and then carve. Once that’s complete you could do the same process and then when you hit carve select use last home position.
