You can send directly from VCarve. When you installed the software, you should have been given the opportunity to install VTransfer. There is not a lot of information on how to use it. I have only used it a couple of times, but it did work. I had to kind of play around and figure it out.
I recently bought a copy of VCarve 9.5, and it indeed has a built-in XCarve post processor in either inches or mm and was planning to start off using Easel to send my saved gcode toolpaths. Or am I mixing up the feature to send direct to the machine which I didnât feel ready for???
Iâm just finishing building my tool database with tool specs more in line with what the XCarve can handle. Then I was going to run a few âfairly simpleâ toolpaths to validate the incorporation of VCarve into my workflow.
Just wondering if you would care to share why you didnât like the VCarve sender.
As always, thanks for your help!!!
