can some help? I’m trying to set up my controller and the limits switches are not responding.
Are they wired correctly?
What aren’t they responding to?
More information will help.
My machine doesnot complete the project and changing the start point. How can I resolve this
@DarshanPendhari I’m going to recommend you start a new thread. You question is different than the OP. You will likely get more responses.
I believe the standard switches have a “normally open” side and a “normally closed” side. Have you made sure you are wired to the correct terminals?
Keep in mind that limit switches aren’t active when using Easel to jog the machine manually.
the y motors are running the opposite direction. need to reverse on
e motor
On the motor that’s going the wrong direction, swap one pair of wires.
