Please add a confirmation dialog, to when we click: Set X/Y Zero.
Too often, I am doing a multi-bit, or multi-staged cut, where I need X/Y Zero to remain the same between sessions. While it doesn’t happen often, I do accidentally click Set X/Y Zero instead of use last, because of the positioning of the buttons between screens.
As with most web standards, I would argue Set X/Y Zero is a destructive action which best practices dictate should have a confirmation dialog to ensure that is what is wanted.
I would really also like to see the Default on that screen be the Use Last X/Y Zero be the default and the larger of the two buttons.
