Set zero to bottom in easel
Is there a way to set zero to the waste board?
I am pretty sure the zero location in Easel is always at the top of the work surface (bottom left corner)
Nope, not as of right now. I asked about this a while ago when I was looking into dragknife options.
I’m curious as to why you think this is necessary?
I’'m sure it has it’s advantages and many CAM software had this as an option. With a drag knife you can just set the 0 to the waste board and not have to try and measure you paper. Here is another advantage:
