I did not set up my Z-Probe when I initially set my X-Carve up. It is installed mechanically and electrically now but I do not know how to go back and get the software to recognize it. At the moment I can only set up the Z-axis manually. Is there some kind of set up instruction for the Z-probe?
You should be able to go the the “Machine” menu option and go back through the machine setup process.
{:0)
Brandon Parker
Thank you Brandon! I’ll give it a try! JR
Thanks Brandon! Worked like a charm!
Fantastic; always glad to help!
{:0)
Brandon Parker
