I am trying to set up a 3018 pro machine and a x carve machine on the same computer with the pro version, why when I tell it to set up a new machine i seem to loose the other machine? It has a drop down box like you should be able to set up more than one and pick the one you want at the time of carving? Every time i set them up i have to measure the z probe and make sure everything is correct before using, its a pain.
Ok, i just figured it out, you have to unplug the usb cable to the machine before it will show both profiles, should work good now. Maybe this will help someone else that is haveing the same problem. Sorry to bother you all. Thanks
