I am having trouble figuring out how to set the XY zero when using larger bits like planning. I have tried setting the XY to the center of the bit and it misses a portion of the side and bottom edge I need to plan. I then tried to set XY where the edge of the bit is over the XY point and that did not work. Can some one please enlighten me on how to set this up. Thanks
Hi Randy, X,Y are set based on the center of the bit and if you’re using easel, than the front left corner if the origin would be the default origin where you’d align the center of the bit to.
Are you surfacing a workpiece or the wasteboard?
Use a smaller bit with a point if you don’t have a touch plate. If you do have a touch plate then use any smaller bit such as a 1/4 inch end mill. Set your X Y zero location with that bit and t hen change to the bit bit and zero your Z axis with it. Design your tool path with the big bit selected. The XY zero location will be the same regardless what bit you change to. Your design software that generates the tool paths will compensate for the diameter of the bit.
Like Randy said, XY Zero are located at the centerline of the bit or spindle. So when you use a more managable bit to find X Y zero, when you change to your big bit you XY zero hasn’t changed one iota. The Z will be the only thing you need to update.
in Easel the XY set comes after the Z location set so how would you set the XY before setting the Z height?
you could set Z, then set X,Y, Then on the very next page select the X at the top right. Now your Z and X,Y are saved.
You can then swap the bit and re-do the carve sequence and set Z zero for this bit and then select “use last X,Y” for the X Y page and it will use the X,Y that you had previously set.
OR you could use a different sender that allows you to set them whenever you like in any order desired. (Like OpenBuilds Control) Best CNC Software is OPENBUILDS CONTROL - Cool Features - YouTube
