is anyone else having problems with easel letting you start a new carve. maybe im doing something wrong but never had this before. it skips the probe set up and when it goes to “use new position” it jumps to the raise bit to start…???
Sounds like you’ve done a new machine setup and told it you didn’t want to use a probe, that’ll get rid of the promp to probe.
There’s 2 ways to get it back either redo the machine setup again (a pain) or go n to machine>edit machine and go to accessories at the bottom and turn on the probe function
