Does the shop vac hose necessarily have to be on the right front side of the xcarve? I would like to put mine to the back of the machine on the right side. Just curious before I attempt if there was any specific reason that by default it is where it is pictured in the assembly instructions. Thank u
Looking at the front of the machine, you could only place it on the back left side end-plate because that plate has the same orientation of bolt holes as the front, right end-plate as well as the dust control bracket. That is without modification anyway…
{:0)
Brandon Parker
switch it out for a pwncnc dust pick up much better set up
