Shortcomings in EASEL
I generate my project files using InkScape.
Most of my .svg files are misinterpreted by Easel.
For instance, single line objects are treated as filled objects and not as outlined objects.
There is no option to override this.
Why is G-code in Easel restricted to the G1 command, and rejects G2 & G3 commands.
Harold
Are you sure they’re single lined?
Can you share an offending SVG?
Here is one file
3a-Single Line|480x480
Harold
Here is a picture of the .svg file.
I am new to this. Hope it comes thru correctly.
Harold
Nope…can you use the upload tool?
Just the way Easel works.
Grbl supports arcs.
I am not very successful uploading the file.
One more time!
Harold
That’s a JPG. Can you get the SVG?
5x6 Combined
Yes. Here it is.
Thanks, Harold
