Should we be following the given depth per pass and feed rate?
should we use the depth per pass and feed rate for the material chosen that defaults on easel?
it seemed to me these were very conservative especially with larger cutters but ive been having a lot of problems figuring out what speeds and feeds to use. getting pretty frustrated with wasting material experimenting
are you guys using these numbers for your projects?
I’ve found that the numbers used for acrylic are good when I use my 1/8", single-flute, up-cut.
